Re: Oil leaks near Bell housing/final drive on 100
Posted by gene bender on April 11, 2006 at 16:39:41 from (66.43.221.211):
In Reply to: Re: Oil leaks near Bell housing/final drive on 100 posted by Ramon from NC on April 11, 2006 at 14:04:36:
They are probably both sides bad and you mite have over filled also. The front tranny seal could also be bad. You have outer sealalso. When i redo them i replace both inner and outer and also the front tranny. Seals will cost around 50bucks but when you are done you will have good brakes and no leaks for your fresh paint job. Your tractor do as you wish.
