Re: Oil leaks near Bell housing/final drive?
Posted by Haas on April 11, 2006 at 17:47:10 from (12.65.72.44):
In Reply to: Oil leaks near Bell housing/final drive? posted by Ramon in NC on April 11, 2006 at 10:56:26:
That picture looks like the final drive for a 140 or similar tractor. I see the Fast Hitch/cultivator brackets in the background. That leak is coming either from the final drive pinion shaft seal, or from the differential (that is on the transmission side) shaft seal, or both. If the transmission is overfilled, that will contribute to the problem. Make sure you only have the transmission filled to the level plug located on the left side behind the brake rod. You have to take the brake rod yoke (clevis) loose to get at the level plug. To replace the seals, you have to remove the final drive and then the brake drum. After you do that, you can get at the seals to replace them.
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
