Re: Bleeding fuel lines
Posted by Ray in Ga. on April 11, 2006 at 20:22:39 from (68.215.207.58):
In Reply to: Re: Bleeding fuel lines posted by Allan In NE on April 11, 2006 at 17:42:02:
Its interesting that this thing uses gravity to pull the fuel down. I keep taking the thing apart looking for trash in the line. The first two times when I disconnected the line from the fuel tank, no fuel came out. Poking a metal rod up in the opening definetly opened it up. The first time I drained the tank and removed the aforementioned bag and spout. The second time I drained it, I could not see anything in there. The only thing I could figure is that the gas sensor float was dropping down in just the right place. So I reformed it (bent the wire). It isn"t being used anyway as all of the wiring has been ripped off of it. Now, each time I disconnect the line, there seems to be no stoppage. I have disconnected both ends of the line from the tank to the first filter and blown it out as you mentioned. Still has the problem. I even removed the filter mounting bracket to see if there was a problem there. It is beginning to look like I am going to have to drain the tank again and clean it out good. It really doesn"t make sense though. I would think that if there is trash causing the problem, it would not remove itself after sitting for a while and then come back later. I am convinced that it is a heat related issue causing some air to expand causing enough pressure to stop the thing up. I really don"t want to replace the filters again, them things are expensive! Anyway, the bleed screw in on the intake side of the filter, so I tend to think the filter is O.K. Guess I will tear into again tomorrow. At least now I know to quit looking for the pump. I may start out by bleeding at the injectors per Vet"s suggestion. Thanks guys.
Home
| Forums
Today's Featured Article -
History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
