Re: w-4 carburetor adjustment
Posted by P Backus on April 12, 2006 at 09:20:14 from (69.128.33.188):
In Reply to: w-4 carburetor adjustment posted by jcarter on April 12, 2006 at 06:00:52:
What the others said is good, but I just wanted to add that if you take the carb drain plug out and turn the gas on, it should run out at a pretty good clip, not just dribble out. That"s after the initial gush of gas from the bowl is out. If it doesn"t run out fast enough, then there is a little bit of rust or something partially blocking the line. Take the gas cap off and look in the tank to the outlet on the bottom to see if you can see somethintg there. Don"t use compressed air to blow back through the carb, as you will collapse the float- been there, done that. Also clean inlet screen where the fuel line goes into the carb. Also, in case you didn"t know, the high speed mixture fuel screw is the one on the bottom of the carb at an angle. The idle mixture air screw is at the throat of the carb, with a spring under it. Paul
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
