Re: 1953 Farmall Super A - Hydralic Problem
Posted by CNKS on April 12, 2006 at 18:22:49 from (204.249.178.138):
In Reply to: Re: 1953 Farmall Super A - Hydralic Problem posted by James Malcolm on April 12, 2006 at 17:40:38:
I don't know, the oil got hot because something was stuck (that's a profound statement). One thing -- the touch control levers do not return to a neutral position as the controls in more modern systems do, although there is as adjustment that does about the same thing -- it does not always work perfectly though. If you hear a whine, you need to move the levers forward or backward until it stops, a constant load on the system will cause it to overheat.
