Re: Oil pump
Posted by El Toro on April 12, 2006 at 18:39:15 from (64.12.116.65):
In Reply to: Oil pump posted by Shaggy on April 12, 2006 at 05:39:55:
What wt engine oil are you using? I restored an A and I used 10-30 wt oil in it when rebuilding the engine. It was in the winter and I left the
oil in and the engine had very good oil pressure
until I started to plow with it. I noticed the pressure was dropping and I thought about the oil.
I pulled off to the side and changed to 30 wt. That solved the pressure problem. Hal
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
