Re: 1953 Farmall Super A - Hydralic Problem
Posted by Hugh MacKay on April 12, 2006 at 19:10:17 from (209.226.247.175):
In Reply to: 1953 Farmall Super A - Hydralic Problem posted by James Malcolm on April 12, 2006 at 17:06:01:
James: Before you tear into that hydraulic system, one question, what position were the hydraulic levers in when this happened? If the levers were all the way forward or all the way to rear, it may be that the hydraulic levers are out of sinc with rochshafts. If that is the case it will get hot very quickly. Go back start the tractor, with with hydraulic levers in mid position. With tractor idling, slowly move the lever (one lever at a time) completely forward, listen for the tractor to start laboring. If that doesn't happen try the rear position of same lever. Then do the same with the other lever. What you are trying to determine here is whether rock shaft completes it's stroke as the lever hit it's stop. You will here it start to labor engine if rock shaft reaches end of stroke and you still have lever travel left. You can adjust linkage to each lever to correct this. Your pto is probably rusted in the shift mechanism, if tractor has been parked for awhile. Usually these will free up with use as oil gets circulated through transmission. Charlie gave you the money fix, I on the otherhand am a Scotsman. He may well be right, but I always try the cheap fix first. It costs very little money to listen and adjust accordingly. Good luck, and come back if you have queations.
Home
| Forums
Today's Featured Article -
Check Your Coolant - by Bill Radford. Great tips on how and when to check the coolant in your tractor.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
