Re: 300 ute - need advice
Posted by Dellbertt on April 13, 2006 at 08:17:00 from (204.39.209.96):
In Reply to: 300 ute - need advice posted by Terry Miller on April 13, 2006 at 04:51:15:
First take a deep breath and dont try to do this all in one day.
Clean the tractor all over will let you get to know it.
Get the IT manual for instructions on adjusting pto.
Make sure the hydraulic vent under the seat is not plugged up. Should be a little cap on it.
The o-ring between hydo pump and engine may be letting engine oil and hydro fluid mix.
This tractor sounds like it was abused and not cared for. Clean everything, change all fluids(some $ here)
After you get it running put a can of DEEP CREEP in the gas to help clean carb and valve.
If you are lucky, with good care and a few hours of running you may have a descent tractor.
2 300U"s Dell
Today's Featured Article - Memories of a Farmall C - by Monty Bradley. When I was a child, my grandparents lived on a farm owned by a Mr. Walters. The crops raised were cotton and soybeans, with about forty head of mixed breed cattle. Mr. Walters owned two tractors then. A Farmall 300 on gasoline and a Farmall C, that had once belonged to his father-in-law, and had been converted from gasoline to LP Gas. Many times, as a small boy, I would cross the fence behind the house my grandparents lived in and walk down the turn row to where granddaddy would be cultivati ... [Read Article]
