Re: FARM ALL 100 A PLOW
Posted by vally farm on April 13, 2006 at 18:18:03 from (207.69.139.158):
In Reply to: FARM ALL 100 A PLOW posted by FARM GAL on April 13, 2006 at 17:24:09:
Should be the same as amy Super A. The drawber gets mounted to the front points, hoop facing foward. The plow has Two bolt holes... the plow mounts with the "mounting plate" to the underside og the drawbar hoop. Use the first LARGE hole for the outside bolt location. Depth control is adjusted by connecting the drawbar to hydro. link. This can be cobbed with a large turnbuckle and a good sized I-bolt. I'vefound that if you want to skip the depth problem, just lock the drawbar in it's lowest position(bolt BOTH sides). The chain goes to the lift bar behind your seat and works off int. hyds. with a bar that runs back along the left side of tractor. They plow SUPER!!! Good luck.
