Re: H leak and charging
Posted by Bob M on April 14, 2006 at 06:07:03 from (69.205.119.215):
In Reply to: H leak and charging posted by 1951farmallH on April 13, 2006 at 18:41:51:
Sounds like your generator is not working. First thing I'd do is replace the ammeter. You can then tell with certainly whether the generator is charging the battery, also whether there is a current drain on the battery with everything shut off.
More than like the oil leak is from one (or both) seals at the front of the transmission. The upper seal is fir the input shaft from the engine, the lower one is the drive for the hydraulic pump.
If you remove the dust cover under the tractor between the belly pump and the transmission you should be able to quickly determine where the oil is leaking from.
Fortunately the seals are cheap and can be replaced without splitting the tractor. You will however need to drop the belly pump to get at 'em.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
