Re: H leak and charging
Posted by Slappy on April 14, 2006 at 06:56:38 from (143.88.85.82):
In Reply to: H leak and charging posted by 1951farmallH on April 13, 2006 at 18:41:51:
The leak you describe may very well be from the belly pump, but it is likely that you have leaky seals in the transmission case where the transmission shaft and the countershaft enter. You will probably drop the belly pump in any event.
Lots of info on changing these seals in the archives, and I would check there first and then we can answer any questions you still have.
