Re: Loading a Cub LoBoy
Posted by Nat 2 on April 18, 2006 at 05:30:51 from (64.80.108.52):
In Reply to: Loading a Cub LoBoy posted by Electric John on April 17, 2006 at 18:12:04:
Having just had a similar experience, here are my thoughts:
1. Depending on which "Cub LoBoy" you have (offset or numbered), and how wide it's set if it's an offset, the tractor by itself can be as narrow as 44". Even the numbered LoBoys with the balooney tires aren't more than 5' wide. If your 6x10 trailer has at least 60" between the wheel wells, it'll go on.
2. Dimensional lumber is of poor quality. The best 2x12s I could find at Lowes weren't enough to hold my LoBoy with rear weights and a front blade for loading. We had to put blocking under the ramps about halfway up. If your 2x12s are old oak, then you've got something, but otherwise, plan on blocking them every 3', or plan on going to the hospital.
3. Weight is your biggest concern when hauling. Depending on what your tractor is equipped with, it could weigh as much as 2000lbs, or as little as 1200lbs. Overload the trailer, and plan on sending someone to the hospital. I hauled mine in a tandem-axle enclosed utility trailer with a 7700lb GVWR. It laughed at the load. You can safely haul a Cub with a much smaller trailer, though.
