Re: farmall c low oil pressure
Posted by captaink on April 18, 2006 at 09:03:47 from (66.115.214.56):
In Reply to: farmall c low oil pressure posted by jerry G.erthofer on April 17, 2006 at 18:54:25:
That is way too low. It should read at least 15 to 20 at idle and more at higher RPM. My B and C both will read 40 or better cold at full throttle and 30 or better when warmed up. You may not think that the low oil pressure is causing damage, but irregardless there is a reason for it, and I strongly suggest that it be found and corrected before damage is done.
