Re: Best way to chisel out a piston
Posted by JAMES WILLIAMS on April 18, 2006 at 12:01:13 from (170.215.132.41):
In Reply to: Best way to chisel out a piston posted by JohnG(TX) on April 18, 2006 at 08:54:48:
drill 2 holes in the top of the piston,stick 2 peices of 1/2in fine threaded all theaaded down both sides of the pins and rods,put washers and nuts on them or what ever else works,make a bridge on top of your motor block with a heavy peise of angle with two holes in it to stick your all thread through and tighten with 2 nuts evenly,using this the same as a puller
