Re: how much does a 560 weigh?
Posted by K.B.-826 on April 18, 2006 at 17:06:56 from (68.115.94.177):
In Reply to: how much does a 560 weigh? posted by M. in sask on April 18, 2006 at 15:46:54:
Base weight for a diesel with zero options and no fuel or coolant was 5,960 lbs, which would already be pushing it for a car trailer with tandem 3,500 lb axles. Figure in coolant, fuel, and common options like PTO, TA, hydraulics, Fast-Hitch, and wide front, and you're at 7500 lbs easy. Add a full set of weights and fluid in the tires, and 10,000 lbs is very possible.
