Farmall Tractors Discussion Board
Re: Rebuild questions
Posted by Bob G. on January 14, 2000 at 05:49:39 from (205.188.198.53):
In Reply to: Rebuild questions posted by Chris on January 13, 2000 at 19:21:55:
Risky business but I think it can be done. I just put engine bearings in my Cub but it was on a stand. I have replaced main bearings with the engine in(in cars)as long as the bearing cap can be removed. Remove the spark Plugs. Once the cap is off tap the bearing back on the side with out the tab to start it coming out. Rotate your crank untill the oil hole is accessable. Place a 1/8" cotter pin in the oil hole and gently flatten the head of the cotter pin so it will pass between the crankshaft and the engine block. Rotate the crank with the cotter pin in position to push out the upper half of the bearing. Be carefull not damage the crank during this whole procedure. Like I said risky businessits still best to have the crankshaft out. Good Luck!!
Post A Followup
: Re: Re: Rebuild questions
Today's Featured Article - Ford Super Dexta - by Anthony West. The rusty blue tractor caught my eye as my truck zipped by the farm implement business. It looked so fornlorn amongst the lineup of newer equipment. But it was just the right size for my small farm. I stopped in and asked the proprietor for further information. "It's a 64 Ford Super Dexta", he said. "It's a tough little tractor, although it's a hard starter being a diesel and all." He did manage to get it running, compliments of a can of ether. Once started it putted along pretty good. It ... [Read Article]
