Re: IH 674 hydraulic problem
Posted by Ted in NE on April 18, 2006 at 20:56:24 from (65.39.111.246):
In Reply to: Re: IH 674 hydraulic problem posted by john bick on April 18, 2006 at 20:22:18:
Just need to bleed the air out of the system. Usually will not have this problem but can happen. On the bottom edge of the MCV below the filter cover, remove the larger hex plug, there will also be a spring and flow divider spool come out. keep the parts in order so can install corectly. Set a bucket under the hole & start the tractor up. Shut off when oil comes out. assemble spring valve & plug should work.
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
