Re: How much does a 856 weigh ?
Posted by Nat 2 on April 19, 2006 at 05:23:52 from (64.80.108.52):
In Reply to: Re: How much does a 856 weigh ? posted by Jimmy King on April 19, 2006 at 02:54:44:
5 tons is empty weight, right?
Wheel weights will add 300lbs per pair.
Fluid in the rear tires will add about a ton.
Suitcase weights will add about 100lbs each.
