Re: Best way to chisel out a piston
Posted by JohnG(TX) on April 19, 2006 at 08:47:32 from (216.136.20.34):
In Reply to: Re: Best way to chisel out a piston posted by JT on April 19, 2006 at 08:34:58:
I have tried that with an iron pipe, and it bent the pipe. This piston is really stuck. I also beat on the top with a wood block and had splinters everywhere. In short, I have tried all the 'usual' methods. I am considering using my torch and melting out the aluminum and letting it fall through to the ground.
