Re: Best way to chisel out a piston
Posted by JohnG(TX) on April 19, 2006 at 09:48:48 from (216.136.20.34):
In Reply to: Re: Best way to chisel out a piston posted by ihc49er on April 19, 2006 at 09:42:27:
This is the method I used to get the sleeves/pistons out of my 1929 Regular. Worked well. I already tried this on this engine. I used the heaviest chain I have to go from one frame rail, to the jack, to the other frame rail. The jack lifted the whole front end, then bent over the iron bar I used to push against the piston. It did not budge.
