1950 H charging
Posted by bear4work on April 19, 2006 at 16:33:48 from (66.168.40.235):
I have a 1950 H. Generator was rebuilt 2 years ago. The ammeter gauge has a crack in it and I can"t tell how accurate it is. It doesn"t seem to be charging. This is a 6-volt system, is there any way to check charging or maybe just clean up some connections? Which ones should i clean or look for? What could be some possible problems with the charging system? Thanks for any help.
