Re: IH Carb rebuild kit price vs others
Posted by RustyFarmall on April 20, 2006 at 06:50:30 from (216.248.75.189):
In Reply to: IH Carb rebuild kit price vs others posted by Randy_NE on April 20, 2006 at 06:11:28:
The Case-IH kit does include several items that you will not find in other kits. You will get all three gaskets, not just two. The new throttle shaft will have the bronze fitting for the governor shaft, not nylon like the others. The Case-IH kit includes a new fuel inlet fitting with screen, not present in the others, and the Case-IH kit also includes a new packing gland for the high speed load adjustment screw. The others don't even know the packing gland is in there. All of this plus the gaskets are much higher quality and WILL fit. I know $90 seems high, but if you buy one of the other kits, you will be visiting your Case-IH dealer to get the rest of the parts you need anyhow, and when you are done, you will have spent just about as much, if not more.
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
