Re: just got sick
Posted by Pullin on April 20, 2006 at 12:18:53 from (71.254.69.37):
In Reply to: just got sick posted by banjo on April 20, 2006 at 11:49:20:
Run it chances are that the water got in the oil pan when the head was pulled off.When the head was removed it most likely filled the cylinders & was not immediately removed,then leaked down in to the oil pan. Run it after draining the oil and replacing it.keep a check on it to see if it comes back.
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
