Re: just got sick
Posted by IBorange in TX on April 20, 2006 at 15:47:37 from (24.155.164.227):
In Reply to: Re: just got sick posted by banjo on April 20, 2006 at 12:17:51:
I agree w/Mike. Just wondering if by accident when you were putting the plug in and raking all the rusty gunk out of the block, that you might have punched a hole in the sleeve, Of course not, what am I thinking about.
If the rusty gunk has been in the block for a long time, there is a possiblity that a pin hole has rusted into the sleeve and allowing antiF to drip into the pan. Remove the plugs and check for sight of or smell of antiF in the cylinders. If so then the sleeve has a pin hole in it. Check every thing before major surgery.
Good Luck
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
