Re: VOLTAGE REGULATOR
Posted by Bob on April 21, 2006 at 06:20:52 from (64.21.249.40):
In Reply to: Re: VOLTAGE REGULATOR posted by Bob M on April 21, 2006 at 05:04:51:
Also, if the regulator is rubber-mounted, there will be a tiny braided ground jumper wire from the regulator to it's mounting base, bypassing the rubber mounts. Those ground leads sometimes break, and the regulator is no longer grounded.
BobM gave you good advice as far as replacing the regulator.
If you continue to mess with it without knowing exactly what you are doing, sooner or later, those big points on the "cutout" part of the regulator are gonna stick closed, and, at shutdown, all the smoke will be let out of the voltage regulator, wiring harness, and maybe even the whole tractor!
(Don't ask how I know this!)
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
