Re: just got sick
Posted by captaink on April 21, 2006 at 06:37:30 from (66.115.214.56):
In Reply to: just got sick posted by banjo on April 20, 2006 at 11:49:20:
Here are my thoughts.
Leave the drain plug out of the pan and set a container under the drain and see if more anti-freeze comes out and how much. A few days will tell the story. No antifreeze coming out, go to church Sunday and praise the Lord.
If it is only a small amount that comes out, put about three heaping tablespoons of pepper in the radiator and drive it until the engine is good and warm. The pepper will work its way into leaking areas and seal them up as good as (or better than) any stop-leak that I’ve tried. Plus my radiator man actually blesses using pepper since it cooks out a lot easier than other products.
If that doesn’t fix it, well…let me just wish you good luck.
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
