Re: just got sick
Posted by Janicholson on April 21, 2006 at 06:50:52 from (199.17.6.175):
In Reply to: Re: just got sick posted by banjo on April 20, 2006 at 18:31:16:
If the cap fits, it is correct. The pressure caps are not compatible with the rad neck.
I hear you on the expenses issue, however it will be worth it for two reasons: 1} it is a cool tractor 2} you will have knowledge that serves a variety of other needs, and keeps the unit going.
It is common for the neoprene orings in the block to harden up. fixing them is not hard but does require disassembly of the engine. To be sure it is the problem, remove the pan and just look for antifreez leaks at the base of the cylinders.
(just costs a pan gasket)
JimN
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
