350u ta help
Posted by John Mosby on April 21, 2006 at 10:32:13 from (63.233.20.32):
help! i have a 350u that has all the t a levers removed ,works fine until i stop in a bind like going up hill, pulling a plow or pushing something then it hangs in gear and i cannot shift gears, is there some way to bypass the t a and just use it as a normal tractor thank you John
