Re: Cub Cadet wiring rehash
Posted by El Toro on April 22, 2006 at 07:40:14 from (64.12.116.65):
In Reply to: Cub Cadet wiring rehash posted by Rcubed on April 21, 2006 at 21:02:16:
You need to check all the wire connections at the
regulator. Those terminal spades on the regulator get rusty over time if left in a damp area. That rust is a good insulator. Had that happen on a JD 140 garden tractor. It had the stator in the flywheel and there was voltage from that. After cleaning the regulator's terminals
the amp meter then showed charging. Hal
