Re: rear main oil seal leaking on MD
Posted by Dave Slater on April 23, 2006 at 17:39:24 from (152.163.100.65):
In Reply to: Re: rear main oil seal leaking on MD posted by Brad in WI on April 23, 2006 at 16:58:35:
Don't have to remove crank,but I would check the main bearings because if to much clearance the seal will start leaking agian later. There was 2 type rear seal used,you will have rope type unless rear main seal update kit was installed sometime.It used neopreme seal.
