Re: ROPS ideas for 300 Utility?
Posted by Janicholson on April 25, 2006 at 07:10:26 from (199.17.6.175):
In Reply to: ROPS ideas for 300 Utility? posted by Kerwin on April 24, 2006 at 18:15:10:
Some will explain that early tractors were not designed for the attachment of ROPS. They have indicated that the castings were not intended to support the shock load, and stress of a roll over. I agree they were never designed that way. With that said there is no reason that a far better than nothing system could be made. Please believe these are only ideas, and not plans. I make no representation that the following is adequate. it is just off the cuff thinking. I would use 2"X4" thick walled rectangular tubing. I would attach it to a 3/4" plate drilled for the four fender mount bolts on the upper axle and use grade 8 bolts in those holes (sandwitching it between the fenders and axle. I would go up from those plates on the inside touching the fenders till I was high enough for head clearance and getting on and off. I would go across under the seat with a lower cross member, then make a square by closing the top. All these would need a 3/8 thick by 8"X8" gusset to triangulate the corners. Gussets would be on the sides of the tubing, not in the center where they might press in on flat surfaces. I would build straight forward on top to even with the side of the torque tube bolting area on both sides, then down to at least two of the bolt holes there. A cross piece ( completing the square of the roof) would go in, allong with the gussets as above. Problems would include seat mounting, clearance for PTO lever, and other access issues. I, again I state these are concepts only. What you do must not compromise your ability to get off fast, nor be more of a scissors threatr than nothing. Remember that existing designs are rolled over and tested prior to being accepted for production. Yours will only have the one chance to save your caboose. Look long and hard at ROPS on other tractors that size, and be stronger than you think is needed. Welds must be professional grade, and the welder may have serious doubts about accepting the job. JimN
Home
| Forums
Today's Featured Article -
Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
