Re: For all you wireing people
Posted by John T on April 25, 2006 at 07:11:57 from (66.244.90.5):
In Reply to: For all you wireing people posted by Levi K on April 24, 2006 at 16:46:32:
Levi, if thats the GM 10 SI self internally regulated family of 3 wire alternators (what it looks like) DO NOT USE THE OLD VOLTAGE REGULATOR WHATSOEVER. The tractor MUST be used at Negative ground and heres how I describe wiring them. Bobs great diagrams puts it in pictures, which they say is worth a thousand words, so take a look and see for yourself. Heres how I wire a GM 10SI Alternator and remember, it requires NEGATIVE GROUND !!!!!!! The big rear main alternator output terminal goes to the wire that used to be connected to the BAT terminal on the Voltage Regulator or Cutout Relay. HOWEVER if that wire wasnt already upgraded, when I convert from a Genny to an Alternator, I replace that wire with a 10 Gauge and it runs from the alternators main output up to the LOAD (NOT to battery/starter) side of the ammeter. I also replace/use 10 Gauge from the ammeters other SUPPLY terminal to the battery/starter. The little side number 2F Voltage Sense Terminal gets connected (use a short 14 jumper wire) right up to to and with the big main output terminal mentioned above. For the little 1R side Excitation Terminal, run a 16 or so gauge wire from the ignition switches IGN (which is HOT ONLY when ignition is turned on) terminal and in series with it place a 10 ohm 5 watt current limiting protection resistor (dont really need that much wattage power rating, but they are heavy duty built and easy to wire). Then in the rare event the tractor continues to run cuz of alternator backfeed when the ignition is switched OFF, I add in series a 5 amp 50 PIV minimum Diode. The diode must be wired with negative cathode end to the alternator and positive anode end to the switch. Again, the ratings are not that exact but about any diode over a few amps and 50 volts or so works. Dont forget to change the battery to negative ground and the coil needs to be wired so the negative goes to ground via the distributor points and the positive gets power from the ignition switch and you have to reverse ammeter leads also if your just now changing polarities. Good luck Ol John T in Indiana
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
