Re: Farmall 140 steering box
Posted by scotty on April 25, 2006 at 07:59:56 from (199.231.49.128):
In Reply to: Farmall 140 steering box posted by Dave in RI on April 25, 2006 at 07:48:54:
Mornin Dave,
You need to evaluate your particular steering box. Meaning, while you turn the steering shaft, is the steering shaft moving in and out, axial play in the shaft? If so this can be corrected by taking the large castle nut out of the front of the box and put in a shim between the outer bearing race and the lip of the castle nut. Also quite often, the steering arm that is on the bottom of the steering box can become loose and can wear the woodruff key on that shaft. You need to determine if those arms have become loose. Also, check that your control arms are tight to your wheel spindles. This should give you a starting point.
scotty
