Re: TD-6 TDBKM71701 264 or 281 ?
Posted by Dave Slater on April 25, 2006 at 08:35:28 from (152.163.100.65):
In Reply to: TD-6 TDBKM71701 264 or 281 ? posted by Guy Votuc on April 25, 2006 at 06:52:22:
You can go by engine serial # to find out what it was originaly.The # is on left front side of block above injection pump and just below head and may have engine size stamped there before serial #. If no serial # it may be replacement block.Think they used 248,264 and,281 but I don't have the serial # breakdown to when they changed.
Some may have been called 6 A .Trouble is if it was rebuilt and it was 248, 3 7/8 inch bore it could be replaced with 4 inch and if it was 264, 4 inch it could be replaced with 4 1/8 which is 281.The only sure way to know is take it apart.
