Re: magnetos are aligned to cam gears?
Posted by El Toro on April 25, 2006 at 09:54:07 from (64.12.116.65):
In Reply to: Re: magnetos are aligned to cam gears? posted by arod on April 25, 2006 at 08:46:38:
You should clean and adjust those points to .013".
Pull the coil wire from the cap and hold within 1/8" of good ground and have someone crank the engine with the starter. Should have a nice blue hot spark. Make sure your grounding wire
switch on the mag isn't in the off postion. This is what's used to stop your engine. Hal
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
