Re: International 3 Bottom Plow for an M
Posted by dej(JED) on April 25, 2006 at 09:54:18 from (66.212.151.134):
In Reply to: International 3 Bottom Plow for an M posted by Richard Fazio on April 25, 2006 at 05:59:24:
Say what you will about the JD plow, but it will pull a lot easier than an IH plow. I guess you aren't really going to be plowing much with it though. It is a to look at thing , I guess.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
