Re: Super A electrical switch
Posted by El Toro on April 25, 2006 at 10:05:06 from (64.12.116.65):
In Reply to: Super A electrical switch posted by rdutt on April 25, 2006 at 09:53:03:
If you have a distributor that's fed voltage from your ignition switch you need to check for voltage using a test lite or volt meter at your coil. I see you didn't mention coil. With a distr you should have a coil. Then the coil is connected to the distibutor.
Are you sure you don't have a mag? They use a grounding switch to ground out the mag. You need to determine which you have. A mag should have H4 on it. They usually have Delco Remy distributors with battery ignition. Hal
