Re: Farmall M with a 12 volt generator
Posted by Bob on April 26, 2006 at 09:19:45 from (64.21.249.40):
In Reply to: Farmall M with a 12 volt generator posted by Russell S. on April 26, 2006 at 07:27:35:
Simply wire it like you would a distributor. It is no longer a mag.
Power from ignition switch to resistor, from resistor to (+) on coil, from (-) on coil to points/condensor.
In my experience, using a condensor from a later tractor with factory distributor will give longer point life than keeping the mag's internal condensor, as, I believe, the values are a bit different.
