Re: Need you help
Posted by old on April 26, 2006 at 13:53:28 from (207.69.139.13):
In Reply to: Re: Need you help posted by Kevin Schumacher on April 26, 2006 at 12:34:02:
Should blow back out much if any. Sounds like you need to remove the valve cover and check for a valve or 2 that is stuck open. You probably have an intake valve that isn't closeing like it should and thats where you get your blow back
