Re: We're ready to torch this 656. Help please!!!!
Posted by dhermesc on April 27, 2006 at 05:38:49 from (68.110.220.22):
In Reply to: Re: We're ready to torch this 656. Help please!!!! posted by Sloroll on April 26, 2006 at 15:33:36:
I agree with Sloroll, its most likely the gasket or the manifold itself has crack that opens up when it gets hot.
Went through the same issue with an overhauled gas engine in a 815 combine. If it would have run long enough to get hot we would have burned it to the ground in the field. Between us and the dealership that did the overhaul it only took the entire fall before we started swapping parts from another engine and caught it. As my dad said he spent almost $2000 on an engine for an overhaul and then spent another $3000 trying to get it to run again.
