Re: We're ready to torch this 656. Help please!!!!
Posted by Janicholson on April 27, 2006 at 06:19:19 from (199.17.6.175):
In Reply to: We're ready to torch this 656. Help please!!!! posted by BRSIL on April 26, 2006 at 15:26:37:
One thing not mentioned in the posts below is the possibility that the fuel system is in fact plugged up. Fuel cap vent with a restriction will allow only enough fuel to intermittantly run full out. These are thirsty tractors, and the more full the tank, the sooner it draws a vacuum and leans out and dies. If the cap vent is wide open, the system needs to be checked for flow at the needle and seat. Make no other changes, place a pan under the carb with the bowl off and turn on the fuel. The stream should be like a big dog taking a leak for 3-5 min. (Big Bladder).
This is a simple check, good luck,
JimN
