Re: We're ready to torch this 656. Help please!!!!
Posted by BillyinStoughton on April 27, 2006 at 06:35:02 from (208.50.85.56):
In Reply to: We're ready to torch this 656. Help please!!!! posted by BRSIL on April 26, 2006 at 15:26:37:
Had this exact same problem on a 544 not that long ago. Same scenario: ran alright for loader work, but once the load increased it was a matter of minutes before the engine wouldn't run above an idle. The primary problem that we found was that the plastic venturi that sits in between the carb halves, had a small fracture in it...and that same venturi sits on a small ring gasket, that in our case had started to deteriorate. After replacing both it has run like a champ since. Cowman also suggested snychronizing the governor/carb which also improved performance. This might be something to look at.
Good luck!
Billy
