Farmall Tractors Discussion Board
Re: IH 4100
Posted by Brian on January 15, 2000 at 05:48:43 from (206.29.120.123):
In Reply to: IH 4100 posted by HS on January 09, 2000 at 19:37:34:
You didn't mention if you were getting any smoke or not. If not look to the fuel system before the pump. Including the hoses as mentioned by Jiff. If you are getting smoke, gray or white I would suspect a compression problem. As a rule of thumb at our shop it would need at least 300psi per cylinder. It may have a leaky delivery valve stop in the fuel injection pump which can be checked by a reputable fuel injection shop. Just some ideas, good luck!
Post A Followup
: Re: Re: IH 4100
