Re: OT/ Trailer brakes
Posted by KEB on April 27, 2006 at 08:01:48 from (192.91.171.36):
In Reply to: OT/ Trailer brakes posted by PUTTER on April 27, 2006 at 06:38:46:
You have electric brakes. When you apply current to the magnets, they want to stick to the inside of the hub. The rotation of the wheel drags the magnet along, pulling on the lever holding the magnet, which causes the level to pivot and spread the shoes at the top of the hub to actually apply brakes. Surge brakes have a sliding connection to the hitch ball receiver connected to a hydraulic brake master cylinder. The brakes on the axles are standard hydraulic brakes. When you stop, the inertia of the trailer pushes against the master cylinder, generating hydrualic pressure to actuate the trailer brakes. Electric brakes have better control, and have the advantage that you can apply trailer brakes independently of the tow vehicle brakes. Surge brakes are common on rental trailers, since a lot of people don"t have electric brake controllers in their vehicles. You absolutely need a brake controller, as the amount of trailer braking is controlled by the current through the magnets. If you simply apply 12 volts to the magnets, it"ll lock the brakes (and probably overheat the magnets). A good electric brake controller like the Tekonsha Prodigy runs around $125. A decent one can be had for less than $100, and for occasional use a cheap one would probably be OK. I"ve seen them as low as $50 or so, but have no idea how well these work. The output of the brake controller goes to one wire on each of the magnets, and the other magnet wire is grounded (doesn"t matter which is which, brake magnets are not polarized). Don"t depend on the trailer frame for a ground for brakes, as a lot of them use the ball as the return path. Provide a ground wire back to the tow vehicle. There are several "standard" ways of wiring trailer connectors. The 7-pin RV type is the most common, and you can get them at Wally World or most any auto parts place. The 4-pin flat connector commonly found on small trailers don"t have enough pins to accomodate a brake connection. We pull an RV as well as utility trailers, & I can guarantee you that you don"t want to pull more than a couple thousand pounds without trailer brakes (plus its illegal in most states). I had a trailer brake fail (broken wire) on the way from California to Colorado with a car on a 7000 GVW flatbed a year or so ago. Even with a one-ton dually tow vehicle, it isn"t an experience I would want to repeat. Keith PS - most states also require a breakaway switch on a trailer that heavy. The breakaway switch connects a battery directly to the trailer brakes if the trailer separates from the tow vehicle. You can buy complete kits (switch, battery & cable) if the trailer doesn"t already have one.
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
