Re: Solid State Ignition
Posted by T.B.W. on April 27, 2006 at 16:17:01 from (4.248.245.69):
In Reply to: Solid State Ignition posted by Allan In NE on April 27, 2006 at 03:13:43:
Allen, I put electronic ignition in my M to try to correct a miss. Didn"t help and it just got worse. Put in a new distributor and it runs like a top. Got the new one for $200 from Steel wheel ranch. The worn out distributor has been my problem all along. It sure does purr now.
