Re: Is your gear shift lever worn?
Posted by Quebec Red on April 27, 2006 at 18:21:55 from (70.83.254.155):
In Reply to: Is your gear shift lever worn? posted by Hugh MacKay on April 27, 2006 at 17:45:11:
After a number of years of use , I believe that MY gearshift lever is not suffering so much from wear as it is the possibility that the construction material of said gearshift is undergoing a transformation. It would appear that as wear (age) increases, there is a possibility that the gearshift seems to become more flexible. I assume that this apparent flexibility would be a design flaw; however upon detailed research, a change of transmission appears to remedy the perceived loss of rigidity.... like going from a 4 speed to a 6 speed; or a Clark to a Roadranger; or from a 5X4 to an 18 speed airsplit double over, without having to double or even triple clutch!!!!!!! Now about Allison automatics........Like I said, perceived.....QR..
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
