Farmall Tractors Discussion Board
Re: 46 Farmall H
Posted by The Red. Congrats Tony! on January 15, 2000 at 07:25:25 from (12.75.198.83):
In Reply to: 46 Farmall H posted by tony on January 15, 2000 at 06:21:55:
Your charge is PERFECT! That is a 12 volt generator and voltage regulator I assume? I get around 7 to 15 between my 3 different Hs. Any more charge than that and they get fairly hot.
I would remove that field wire between the field post and the bolt. You shouldn't need it. Unhook it and fire up the H and see if she is still charging OK.
That NAPA part number is for GE light bulbs that replace the current 6 volt bulbs. Not a sealed beam but a bulb that works in the original H light bulb socket assembly. They are pretty bright. When the lights are on, you will show zero to maybe a slightly negative charge.
Post A Followup
: Re: Re: 46 Farmall H
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
