Posted by redrider on April 09, 2009 at 19:39:58 from (66.235.45.149):
In Reply to: 53 SH disc brakes posted by Deano4863 on April 09, 2009 at 19:12:07:
This is the method I used when I reconditioned the disc brakes on my 300F. To make these brakes like new you have 4 different surfaces to turn. The outer housing, the two actuaters and the bull pinion bearing retainer. The total amount removed on these 4 surfaces needs to be removed from mating surface of the brake housing. If this is the first time anything has been turned then usually you can measure the indentation wear surfaces to get a rough idea how much wear deteration there is. You almost have to reassemble the brakes and check the amount of travel in the actuaters. When you have the brakes adjust up (not to tight) you want the two actuating links that attach to the operating rod yoke to be as straight as possible this will give you more leverage when actuating the brake. I hope I have not totally confused you.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
