Re: question about the regulator
Posted by Bob on April 27, 2006 at 19:13:43 from (64.21.249.40):
In Reply to: question about the regulator posted by Levi K on April 27, 2006 at 18:47:45:
You can connect the large wire leading rearward to the regulator's BATT terminal, where it belongs, along with the large wire leading forwards to the alternator's large output stud, as these 2 wires need to be connected to carry the charging current from the alternator to the battery. It is OK to use the BATT terminal as a junction point for the two wires, or just connect them together, and toss the regulator.
Is there an "idiot light" charge indicator in the dash? If so, that's where the yellow wire is from.
This can be connected to the alternator's #1 "switched excite" terminal, then jumper the alternator's #2 "voltage sense" terminal to the alternator's large output stud.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
