Re: 656 manifold question
Posted by Allan In NE on April 28, 2006 at 04:45:52 from (148.78.243.26):
In Reply to: 656 manifold question posted by matt in pa on April 28, 2006 at 04:34:00:
Matt,
That is the weight for the internal heat riser. Shaft should be "thermal-sprung" on the outside face of the manifold.
When the engine is cold, this thing re-routes the exhaust around the intake to warm up the intake and carb.
Allan
